Leaky Fuel Tank Options
Old Jul 23, 2012 | 09:48 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I'm trying to figure out the best course of action to fix my leaking filler neck.
Last year, factory pump died and was replaced with a walbro unit. During that time I noticed the solder around the filler neck had a crack in it and tried fixing it. It seemed to hold for a few months, but now it leaks on hard cornering.
What options do I have, from what I have gathered is these are my options:
1. Buy a aftermarket tank, but have heard the only aftermarket is the spectra tank and the fitment sucks on those.
2. Take my tank to a radiator shop and have the neck re welded.
3. Replace the tank with a plastic LS1 tank. This seems like an awesome swap since it is lighter and plastic so it will never rust, however I can not use the walbro I just bought with it so I would loose money on that. I would need to make some custom lines and replace the fuel level sender to make my gauge work properly.
Any other options/recommendations???
Old Jul 23, 2012 | 09:59 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Leaky Fuel Tank Options
If its not rusty I'd go with number 2.
Old Jul 23, 2012 | 10:15 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Thanks, the tank is in GREAT shape. less than 80K miles and never driven in the snow, and rarely in the rain.
Old Jul 23, 2012 | 02:21 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I just repaired mine with some 2 part epoxy for marine applications. I had a hole in the top that some idiot cut into it while extracting the sending unit through the car body under the hatch.
I agree that the radiator repair shop is the best way.
Infested
May 22, 2018 11:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
