700R4 shift points with HSR
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
hi, I just installed an HSR a month ago. So last night I decided to try out the HSR at WOT, and I noticed that my 700R4 in drive kept shifting at 5000rpm while the motor was still climbing. How do I fix this problem? I was hoping the transmission would automatically shift around 5500-5800 rpm. I really don't want to shift manually on the 700r4 from 1-2 2-3 because I feel that it would hurt the auto transmission since it doesn't have a shift kit.
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: 700R4 shift points with HSR
Search the 'Transmission' forum for how to recalibrate the transmission governor, which adjusts the WOT shift points.
Bill
Bill
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Only in the 4L60E version. Ours are based on the governor and the TV cable.
Car: 92 T/A 'vert
Yes but does so by altering line pressure which is a good way to smoke a 700R4.
When I reinstalled the HSR, I never made any adjustments to the tv cable. The throttle body connection goes out slightly ( 1-3 centimeters) further than the stock tpi connection. My automatic shifts at normal, light acceleration are the same. I shift into 3rd gear at 25mph, and 4th gear at 35-37mph. I want to know how many people with an HSR adjusted the tv cable. The only cable i adjusted was the cruise cable.
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
i was playing around with my tv cable awhile ago and that ajusted normally vs just pulling tv cable till you hear 1-4 clicks shifted up in higher rpm wot and part trottle i think it was 500-1000rpm diffrence but you can ruin your trans by doing that from what i hear there was a article on tpis book about ajusting tv cable to get the best shift points for 1/4 mile i can take a pic and posted
Car: '87 Z-28
Engine: LT1-topped 400
Lot of people are saying a lot of things here, but there's only one right way to handle this. First, you need to know that your TV cable does not control WOT shift points. Assume your throttle body moved when you did your intake swap, or that the previous owner was a jerk and misadjusted the cable, because the cable only takes half a minute to adjust and could save your transmission. Follow the instructions here to set it.
The WOT shift points are controlled by the transmission governor. This is found within the driver's side of the transmission, near the back, behind a round metal cover. It is removable with the transmission in the car and takes only a couple minutes to pop out. Some transmission oil will leak out, so be prepared to catch it. The weights and springs on the governor control the shift points, adjustment kits with a variety of weights and springs are available from a couple manufacturers. It is mostly a trial and error method to set the shift points, this post should help you get started.
Engine: 305 to 350
Axle/Gears: 10 Bolt
not denying that as I said in my post that you can RUIN YOUR TRANS But thanks for the links
86CamaroDan
Sep 29, 2015 10:08 PM
TheTraut88
Sep 7, 2015 05:22 PM
someone972
Aug 30, 2015 12:52 AM
