Shifter won't go into park, overdrive, 2 and 1 gear
Old Aug 18, 2012 | 05:22 PM
Jfinnkma91's Avatar
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
I can get it to go into park if I jerk the shifter forward real hard. And now lately i can't shift into the overdrive gear or 2 and 1.
I took the cable off the transmission and the linkage moves fine. I think it's the shift. But what the hell would cause this so I can fix it?
"it's always one thing after another"
Old Aug 18, 2012 | 05:25 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Shifter won't go into park, overdrive, 2 and 1 gear
Replace the cable
Old Aug 18, 2012 | 05:27 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
The cable is separated inside the cover and needs to be replaced. It is frayed inside and is jamming up.
1992rs/ss
Jan 31, 2025 05:10 PM
camaro11j
Sep 19, 2018 08:49 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Dialed_In
Aug 20, 2015 01:45 PM
