HELP! 88 Camaro 305 TPI revs super high when started
Old Jul 27, 2012 | 12:31 PM
BerryPerry's Avatar
Car: 1988 Camaro IROC
Our camaro sat for 3 years without being started. We installed a new battery in the car and it started right away, but the engine immediately rev'd full out. Just crazy HIGH REVS. The car was turned off immediately. Does anyone have any idea of what this may be?
Old Jul 27, 2012 | 01:27 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: HELP! 88 Camaro 305 TPI revs super high when started
Rusty , bound up from sitting , throttle cable holding the throttle plates open ?
Massive air leak from deteriorated vacuum hoses ?
Cruise control unit somehow AFU'd and holding the throttle open ?
IAC malfunction ?
Little Bro pushing the gas pedal to mess with ya ? (seen THAT happen once)
Throttle plate shaft sticky/binding not allowing it to close to proper idle position ?
Bad return spring for throttle plates ?
There are the first things I'd be lookin for ....
Old Jul 27, 2012 | 01:43 PM
BerryPerry's Avatar
Thanks alot. I will try what you have listed.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
