AC quit working
Old Jul 28, 2012 | 06:56 PM
Brock Lee's Avatar
Car: 1991 Firebird Formula
AC quit working
1991 305 TPI, all stock.
Here is the breakdown AC did work, but stopped sometime between last fall and this past spring. I assumed it may be low on refrigerant, so today I took it to have it charged (same place did it last time) and they said it wasn't low. They topped it off anyway, but didn't even bother charging me as it was such a small amount.
The compressor is getting power, but the clutch is not engaging. I can move it by hand. The secondary fan that normally comes on when I turn the AC on is also not coming on.
I checked the fuse, it looked fine, but I changed it anyway. No change.
Where should I start looking?
Thanks!
Old Jul 28, 2012 | 07:16 PM
Kush's Avatar
Re: AC quit working
If the system is charged and the fuses are good, it could be a bad pressure switch in the engine bay or bad wiring in that circuit.
Old Jul 28, 2012 | 08:15 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: AC quit working
Try to jumper the low pressure switch connector to see if the compressor cycles. If it doesn't, it may be the cycling switch in the compressor itself. You may also have a bad fan relay. There is a test for that but I'm away from my manuals so maybe someone on here can walk you through it.
Old Jul 28, 2012 | 08:54 PM
Brock Lee's Avatar
Re: AC quit working
Is the pressure switch the one on the accumulator?
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: AC quit working
It could also be the clutch is bad/not engaging. Turn your AC on and check for power at the leads on the compressor.
Old Jul 28, 2012 | 09:11 PM
Richboll's Avatar
Engine: 305 TBI
Re: AC quit working
Yes and as Ozz says, you may just have a bad clutch on the compressor.
Ozz1967It could also be the clutch is bad/not engaging. Turn your AC on and check for power at the leads on the compressorOzz1967It could also be the clutch is bad/not engaging. Turn your AC on and check for power at the leads on the compressor
Old Jul 28, 2012 | 09:38 PM
Brock Lee's Avatar
Re: AC quit working
I did check that first thing, and I was getting power.
Would that also explain why the secondary fan is not going on?
Old Jul 28, 2012 | 10:39 PM
Brock Lee's Avatar
Re: AC quit working
I jumped the terminals for the pressure switch and it came on.
Thanks guys!
92camaroJoe
Jul 29, 2023 07:57 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
92camaroJoe
Aug 13, 2015 06:07 AM
