HELP! Stranded with a no start.
Old Aug 3, 2012 | 04:09 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
So I stopped for gas and my 91 B4C decided not to start. I'm writing this from my phone at the gas station. I'm pretty sure fuel is good at 47 Pei cranking and no throttle adjustments are helping. I attempted to jump it with no change in results. My brother held the coil wire close to the terminal to see if it would spark and the car started but dies as soon as we connect it. So it seems to me like there's insufficient resistance somewhere. Does it sound like a bad coil to anybody else?
Old Aug 3, 2012 | 08:28 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: HELP! Stranded with a no start.
Or the ignition control module (ICM ) in the dist
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Old Aug 3, 2012 | 02:42 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Most likely the coil. If I saw this at the shop, I would throw a tester coil on it before I looked at anything else.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RS Reaper
Oct 17, 2018 07:52 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Jlanz55
Sep 29, 2015 08:55 AM
