how to remove cam dowl pin?
Old Aug 3, 2012 | 09:18 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i ordered an lt1 cam for my build and it doesnt have the pin sticking out of the end of the cam, but my original cam does, how do i remove this pin and put it in my new cam?
Old Aug 3, 2012 | 10:39 PM
Re: how to remove cam dowl pin?
Punch.
Hammer.
Installation is the reverse of removal.
Old Aug 4, 2012 | 07:32 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I have also had to do a little work on the part of the pin going into the new cam. I have had to peen that end ever so lightly to give it a snug fit. A little Loctite for insurance.
Old Aug 4, 2012 | 10:19 AM
Engine: L31 350
could i use a pair of vice grips to remove it or is a punch and hammer the only way?
Old Aug 4, 2012 | 11:05 AM
Try em and see
Old Aug 4, 2012 | 11:10 AM
brando54009's Avatar
Car: 82 firebird
Engine: a few
Transmission: th350
Axle/Gears: wondering this myself
you could also just go to the hardware store and get one the same size. if im correct the pin is more for locating and its not much of a load bearing piece.
Old Aug 4, 2012 | 12:36 PM
Engine: L31 350
I think the pen goes into thr timing chain gear and that's what moves the timing components.
Old Aug 4, 2012 | 12:51 PM
Car: 82 firebird
Engine: a few
Transmission: th350
yea but i belive its just there to locate the sprocket correctly
Old Aug 4, 2012 | 01:13 PM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
Vise grips...
Old Aug 4, 2012 | 09:22 PM
Damon's Avatar
You can Vice Grip it out. Might have to do some slight filing afterwards to get the "teeth marks" off it so it will slide into the hole in the cam gear, though.
Obviously, bench test this BEFORE you go for final engine assembly.
Once the cam gear bolts are tightened down the dowel's job is largely done. It does not bear a load. It's just there to index the cam to the cam gear. Unless, of course, you don't properly tighten the bolts!
Frozer!!!
Jan 19, 2024 04:55 PM
anesthes
Mar 10, 2016 10:35 PM
theshackle
Aug 22, 2015 06:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
