91 formula throttle stuck open while cruising.
Car: 91 formula
Engine: 350 tuned port. bolt ons
So for the past 2 weeks my throttle keeps sticking open while cruising on the streets. it only seems to happen after i get off the interstate and start driving on normal streets. i almost ran into the back of a semi last night so I need to get this fixed. this is the second time its ever happen and i have to throw it in N and give it a rev or two seems to stop it. Im going to spray some white lithlium base spray grease on the throttle wire. Anyone else has ideas on what i could do more.
Car: iroc z
Engine: 383 in the works
Axle/Gears: 3:73
Re: 91 formula throttle stuck open while cruising.
Have you checked you throttle body shaft for movement. When the throttle shaft wears it wears into the body housing. Rochester didn't use bushings for the shaft to ride on.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
IAC broken/gunked up?
Car: 91 formula
So i looked this morning. Looks like the throttle body wire the part of the wire that wraps around the outside side of the throttle body is loose and i can move all the wire windings with my hand. Im sure your not suppost to do that.
Car: 91 formula
from what I'm reading on internet forms are they have vacuum wires that are leaking. Anyone know how many vacuum lines are on a tpi throttle body?
Engine: 4++,350 & 305 CIs
3 Vac lines. 2 on the pass side and one on the bottom.
mdtoren
Aug 16, 2015 05:45 PM
