Fuel Problems at High RPMs
Old Aug 9, 2012 | 05:41 PM
CamaroX84's Avatar
Mods are in the sig. I also installed a set of 1.6 roller rockers. After I did that, the motor stars backfiring and falling flat at high RPMs (5000+). I've tried everything from jets to ignition components. What I'm thinking is that I have a problem with the bowls running out of fuel.
I used to have a TPI system on my car, so I have a factory in-take fuel pump running fuel through stock lines and into a regulator to bring it down to 7 PSI for the carb.
Do you think this is a fuel pump or a fuel line (size) problem, or possibly both?
Thanks in advance.
Old Aug 9, 2012 | 05:52 PM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Re: Fuel Problems at High RPMs
did you just do these engine upgrades or did this just start happening.
Old Aug 9, 2012 | 06:34 PM
CamaroX84's Avatar
This started happening immediately after the installation of the 1.6 rockers. Everything else was already done and I hadn't noticed the problem.
Old Aug 9, 2012 | 07:29 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Too much preload on the lifters. Back the rockers off and reset the lash. 1/2 to 2/3 turn after 0 lash. I assume this is a hydralic roller?
Also assuming your springs can handle an extra .030-.040 of lift without floating the valves....
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
