help with squealing noise?
Old Aug 11, 2012 | 01:20 AM
maro3rdgen's Avatar
Car: 1989 camaro RS convertible
Engine: 305 TBI stock
Transmission: 700-r4
alright ill try to explain this. 89 camaro rs all stock...runs good but the past two days i have been hearing this light squeaking/squealing noise that i cant really pinpoint where its coming from. its only when the car is moving but as soon as i touch the brakes the noise stops. and it doesnt squeak at all when parked or stopped. if you can help me it is much appreciated thanks.
Old Aug 11, 2012 | 01:36 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: help with squealing noise?
Do you have a AC? and does it make noice after turning the AC on? Never had brake problems.
Old Aug 11, 2012 | 01:39 AM
maro3rdgen's Avatar
It has a/c but it doesn't matter if the a/c is on or off
Old Aug 11, 2012 | 01:46 AM
Engine: MPFI
I had some squealing noise recently. Funny thing is my power steering bracket broke. And when it did my serpentine belt fell off, so i had to buy a new one. After replacing it never had another noise. And my car runs better then it ever did. i think i had some slack or something. When i would turn ac on i would have less power. But i bought the best belt and it really made a difference. Has a 3 yr warranty too! Might be something totally different for you. But i did have a squealing noise.
Old Aug 11, 2012 | 05:45 AM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
If the car is stopped but running does it squeal when you turn the steering wheel? Water pumps can squeal when they are starting to go bad. Squeals usually are belt related. Squeeks tend to be suspension related. With the car parked and off try walking around to each corner and push the car down on the suspension and let it come up. See if you can replicate the squeek.
Old Aug 11, 2012 | 11:20 AM
maro3rdgen's Avatar
doesnt squeal when turning the wheel and just tried pushing down on the car to check the suspension and still no squeak. so im assuming something with the belt?? the belt itself is fairly new.
Old Aug 11, 2012 | 12:30 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Brakes need replaced.
Old Aug 11, 2012 | 12:35 PM
Car: 1988 GTA
Engine: 400 CI
lol...good point! Does it only do it when you brake? Did it squeal before you changed the belt?
Old Aug 11, 2012 | 12:43 PM
maro3rdgen's Avatar
No never squeaked before and I didn't think it was brakes because it squeaks while I'm moving then it stops as soon as I touch the brakes. Could it still be the brakes?
Old Aug 11, 2012 | 12:50 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Ya pull one front wheel off and check the pads.
Old Aug 11, 2012 | 12:56 PM
Car: 1988 GTA
Engine: 400 CI
Brake pads have little metal shavings in them at the end of the pad to warn you that it is time for a pad change. Very well could be your problem.
Old Aug 11, 2012 | 12:59 PM
maro3rdgen's Avatar
Ok thanks for the input guys ill check it out
Old Aug 11, 2012 | 01:15 PM
maro3rdgen's Avatar
alright definitely looks like its the brakes. the front pads are very thin. ill replace them today or tomorrow. thanks again guys much appreciated.
Old Aug 12, 2012 | 12:25 AM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Your welcome, please come again
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
