Strange Noise
Old Aug 11, 2012 | 07:25 PM
Jdgosselin44's Avatar
Car: 1992 Camaro RS
Engine: 305 tpi
Transmission: Manual
Axle/Gears: Stock
Strange Noise
I have a 92 RS, and when im at a certain point in accerleration, there is a whistling like noise, almost sounds like a bad bearing. But when the gas pedal is beyond that point and before it, the noise isnt there... ive spun a few pulleys and the water pump pulley was making a rubbing noise and i replaced the whole pump with no change. Suggestions?
~Josh
Old Aug 12, 2012 | 12:16 AM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Re: Strange Noise
What kind of air intake do you have? It could just be the air flowing just right making it whistle.
Old Aug 12, 2012 | 05:37 AM
Car: 1992 Camaro RS
Engine: 305 tpi
Axle/Gears: Stock
Re: Strange Noise
I have an open circle filter. Kinda thought it may have something to do with that cause that's where the noise could be coming from. I'll check it out
Old Nov 12, 2012 | 11:21 AM
kkeat1's Avatar
Re: Strange Noise
Any word on this Jd? Were you able to find the cause. I have this same exact noise happening on my 88 TBI. I too have an open element.
Any thoughts?
Old Nov 12, 2012 | 05:45 PM
Car: 1992 Camaro RS
Engine: 305 tpi
Axle/Gears: Stock
Re: Strange Noise
Yes it was the open element filter.
Old Nov 12, 2012 | 07:45 PM
kkeat1's Avatar
Re: Strange Noise
Thanks. Did you find a fix?
Old Nov 13, 2012 | 12:55 AM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Re: Strange Noise
Welcome to the world of open element filters
I've ran an open element K&N on the end of my intake for years, and there always has, and always will be that distinct, unmistakable whistling/sucking sound..
Just something that comes with the territory
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
BWilcox
Sep 20, 2015 12:19 PM
