todays score, what ya think?
Old Aug 14, 2012 | 08:07 PM
highgear's Avatar
Car: 1988 IROC-Z
I got a deal on some used parts, not sure if there any good for my build so I'm lookin for opinions. I got a HEI distributor, no cap and kinda dirty. A 4 barrel carb quadrajet needs some reconditioning, a "dyna mod" distributor module, not sure if it even works. A flywheel/flexplate not sure how to tell the difference, not sure what it goes to but its stamped with "victory lane performance 13", a pair of header collectors. Got it all for a $20.
Good deal? Also does anybody know anything about the victory lane flywheel?
Or the dyna mod module?
Old Aug 14, 2012 | 08:15 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: todays score, what ya think?
Flex plate is thin & light-weight.
Flywheel is thick & heavy.
Get a manual and rebuild kit for the carb.
Clean the distributor, call a performance shop & see what it would cost to test it.
Old Aug 18, 2012 | 08:33 PM
highgear's Avatar
Car: 1988 IROC-Z
I'm having a heck of a time coding this quadrajet. Its stamped by Carter for GMC 17056600.
Old Aug 18, 2012 | 09:13 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Flex plate has hole and mounting tabs for a torque converter.
HEI for $20 alone isn't bad... I've been running the same old one on a few different motors now.
Old Aug 18, 2012 | 11:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The Carter Q-jet was made by Carter for Rochester when Rochester could not keep up with demand.
17056600
170 = 1976 and newer
5 = 1976 - 1979
6 = 1976
6 = Varijet (2-bbl) Federal Standards
0 = Chevrolet
0 = Automatic Transmission
Are you sure that second 6 is a 6? A 4 barrel should be a 2 or a 5 depending if it's Federal or California standards.
Old Aug 19, 2012 | 06:38 PM
highgear's Avatar
Car: 1988 IROC-Z
Its clearly a 6 and a 4 barrel. That's what had me so confused.
Old Aug 19, 2012 | 07:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Doesn't really matter. The rest of the code says it's a 1976 q-jet. Only useful if you're building a numbers matching car or racing in something like Stock Eliminator where a date code means something.
Old Aug 20, 2012 | 06:55 AM
highgear's Avatar
Car: 1988 IROC-Z
Yeah. I guess that's true. I'm pretty excited to tear into it. Never rebuilt a carb before.
Linson
Oct 24, 2025 02:00 PM
86IROC112
Nov 7, 2015 06:50 AM
bjpotter
Oct 4, 2015 07:48 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
paul_huryk
Oct 1, 2015 04:27 PM
