Poor sealing at gas cap
Old Aug 18, 2012 | 01:57 PM
winger67's Avatar
I have gas coming out the filler neck when I take right turns and the tank is more than 2/3 full. Looks like the filler neck has slight damage to it probably when the pump was changed. Thought about trying to tap it flat with a hammer but concerned about sparks near the tank. Any suggestions on how I can flatten the sealing surface?
Old Aug 29, 2012 | 01:11 PM
AdamsRS25's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Poor sealing at gas cap
Have the same problem with my 88 Iroc Z Convert. And this was a new tank. still have not fixed it though. Good luck.
Old Aug 29, 2012 | 01:15 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Use brass hammers or hard plastic. Try to put a seal in the tank neck b4 you start
1992 Trans Am
May 10, 2023 07:19 PM
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
