Camaro low power and crazy shake
Old Aug 19, 2012 | 04:46 PM
MOULTY0717's Avatar
Engine: 383 Stroker
i had a master mechanic install a 383 stroker i bought turn key from united racing engines. there is a crazy shake at idle and at higher rpms. shakes car and steering wheel . car isnt very fast either. engine has dyno of 417 horse and 425 ft torque. my moms 305 would smash it!!! Any suggestions? not sure what would be causing the problem. Thanks.
a little info on engine: carbed edelbrock 750, mallory hei dist no vacumn advance per ure, holley fuel pump, regulated at 7 psi, hedman headers
Old Aug 19, 2012 | 08:08 PM
Re: Camaro low power and crazy shake
Check for plug wires #5 & #7 swapped
Old Aug 19, 2012 | 08:15 PM
chevcam86's Avatar
Car: 86 camaro
yea id check all the wires to make sure there in the right order AND not grounding out on anything(headers intake melted ect.) if that doesnt help make sure your timeing is correct. if its none of that id pull all the plugs out and take a look at them
Old Aug 20, 2012 | 05:58 PM
MOULTY0717's Avatar
Engine: 383 Stroker
Checked timing and it is good based on info on engine paperwork. checked wire order and it is good. no melted wires or open spots. pulled plugs and they are black as hell. What would cause that so i can prevent it from happening again? does the carb need adjusting? I am not very seasoned when it comes to carbed engines.......Thanks for the input.
dont know if this matters, but engine sat for over a year after i got it and i installed an electric choke on the carb. not sure if that has any bearing.....
Old Aug 20, 2012 | 09:04 PM
chevcam86's Avatar
Car: 86 camaro
if the electric chok isnt openong all the way it could be running rich. thats why your plugs are black. (or your rings are bad and its oil fouling bad) try holding the choke open all the way with some wire and go for a test drive and see if that helps any
Old Aug 22, 2012 | 09:09 PM
MOULTY0717's Avatar
Engine: 383 Stroker
so i had a different mechanic look at it and he says its dumping gas......ok? he did a little bit of tuning on the carb, seemed to run better. wants to check timing again. yay. seems to think the shake is from the headers hitting the frame in a spot. Frickin headers have been giving me nothing but problems. We'll see what happens............ I appreciate the input. Thanks
Old Aug 23, 2012 | 06:13 PM
MOULTY0717's Avatar
Engine: 383 Stroker
And it gets better..... looking at the trans today and the belllhousing is broken right in half. wtf i am having the worst luck with this car it is unbelievable what would cause the belhousing to break? its a remaned tranny with no miles on it.......
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fronzizzle
Aug 19, 2015 01:36 PM
novaderrik
Aug 10, 2015 12:44 PM
