how to remove front acessorys, brackets ect?
Old Aug 19, 2012 | 09:22 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
im going to be going to a junkyard soon to be pulling for a serpentine setup for my motor and i need to know what all tools ill need to remove everything, i know ill need a harmonic balancer puller for the balancer, but do i need any other special tools for the pulleys or do they just bolt on or can i take them off with the brackets? help!!
Old Aug 20, 2012 | 12:32 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: how to remove front acessorys, brackets ect?
If you plan to remove the P/S pump from the bracket, you will need a P/S pulley remover to remove the pulley first, as it blocks access to the pump to bracket bolts. You can remove the brackets, with the P/S pump still attached by disconnecting the lines. Be aware of the 15mm head bolt behind the P/S pump and the bracket there that goes to the block. The heads of the A/C compressor bolts are relieved on one side to allow them to be pulled out past the clutch hub. A few of the bolts attaching the brackets to the engine are hidden in recesses in the brackets. The bolts to the engine are standard size with 9/16" heads. the fasteners on the accessory brackets themselves are all metric with 13mm or 15mm heads
The balancer is not part of the crank pulley. The pulley attaches to the balancer with 3 bolts and the crank bolt. The balancer is the same as the one on your 86.
Old Aug 20, 2012 | 02:47 PM
Engine: L31 350
Might add that I'm pulling these off a 305/350 for my 350 Vortec. I messed up my original balancer so I'm going to pull the balancer off when I pull the rest of the parts. Aslong as I can just pull everything I don't care if the acessorys stay in the brackets. I just need all the brackets To come off
Old Aug 20, 2012 | 02:59 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Don"t forget to take a few torx bits and extras. There is 4-5 bolts and or studs holding each bracket to the heads and block. There are also 1-4 solid metal tube supports depending on year and model of car.
Old Aug 20, 2012 | 03:09 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Good luck how many thirdgens are in your wrecking yard.
Old Aug 20, 2012 | 03:49 PM
Engine: L31 350
the one I want is a 92 tpi car but it's missing it's hood and I don't know how long the motor has been exposed to the elements and it worries me. But the yards I go to are VERY plentiful of third gens.
1992 Trans Am
May 10, 2023 07:19 PM
gta power
Aug 13, 2015 06:15 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
3rdgenparts
Aug 8, 2015 07:09 PM
