Engine Rattle Noise.
Old Aug 25, 2012 | 05:07 PM
pmccall2's Avatar
Car: 85 Camaro Berlinetta
Engine: 2.8l V6
Ive been trying to sort this out for awhile now, but can't seem to track it down.
I have a rattle noise coming from my tbi 305, and I cant figure out where it is coming from.
Ive seafoamed the engine, removed the smog pump (new belt and tensioner), and changed the alternator, none of which has helped.
It rattles between 800 - 1500 rpm, and will only do so after it has warmed up.
After it has warmed up and is at idle the rattle is intermittent, it will rattle for a few seconds, stop, then start again.
The rattle doesn't change with the RPM (doesn't get faster/slower), but it goes away after 1500 ~rpm.
Old Aug 25, 2012 | 05:23 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Engine Rattle Noise.
Grab a length of heater hose. Hold one end of the hose to your ear and move the other end around the engine while it's rattling. This might narrow it down for you.
Old Aug 25, 2012 | 08:33 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Try checking your exhaust components, like heat shields, clamps, hangers.
Old Aug 25, 2012 | 08:44 PM
slayers90RS's Avatar
Car: 1990 RS Camaro
Engine: 305 c.i. v8 tbi all stock
Transmission: 700r4 bone stock
I had an almost identical problem... still do actually. If it sounds like a bad bearing type of rattling from the right side of the engine compartment its probably your powersteering pump. Mine is shot and rattles intermitantly just as yours does in the same rpm range as well. I searched for a little while but came to that conclusion.
Old Aug 25, 2012 | 08:45 PM
Car: 1990 RS Camaro
mine is also a 305 tbi 1990
Old Aug 25, 2012 | 08:55 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I have the same intermittent rattle and it's the RH donut gasket between the manifold and the y pipe. I can actually see that rattle back and forth when it makes the noise.
It sounds like a bag of loose change rubbing on a pulley but it's not.
Old Aug 25, 2012 | 09:09 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
PCV valve rattles with engine vacuum. Like was said earlier, use a length of hose to your ear and move around and listen.
theshackle
Sep 17, 2020 08:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 8, 2015 12:07 PM
