350 engine timing
Old Aug 25, 2012 | 05:30 PM
mcneff's Avatar
350 engine timing
Hey guys, new to this site, but have a problem. i have a chevy 350 motor in my jeep wrangler. the motor has an edlebrock rpm cam and intake on it with a 670 holly truck avenger carb. right now to get it running decent my timing light shows 42.2 degrees advanced. what is my problem. the timing dots for the timing chain is lined up, put a new stock harmonic balancer on it. and have tried two differet distributers.
Old Aug 25, 2012 | 06:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 350 engine timing
What balancer and timing pointer did you use?
Old Aug 25, 2012 | 06:20 PM
mcneff's Avatar
the balancer is a stock on for the motor and the timing pointer is on the right side of the timing cover. also the stock timing chain cover.
Old Aug 25, 2012 | 06:21 PM
mcneff's Avatar
when cylinder #1 is dtc the timing line on the balancer and the 0 degrees mark on the timing chain cover line up
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
