Only starting when cold.. Ignition module? Coil? Cap?
Old Aug 25, 2012 | 06:07 PM
88mauiblue's Avatar
Car: 1988 Maui Blue Camaro
Transmission: Manual
I replaced the starter thinking it would solve my problems but it didn't. The car starts fine after it's been sitting for awhile, but after running it for just 15 minutes and shutting it down it won't turn over. The new starter sounds good and is cranking but it won't go further than that... Any ideas? or similar problems???
thanks in advance
Old Aug 25, 2012 | 09:04 PM
cjberquist88's Avatar
Car: 1988 iroc z
Engine: 5.0 tpi
Transmission: 5 spd manual
Re: Only starting when cold.. Ignition module? Coil? Cap?
is it FI or carb?? i had an 81 camaro that did the same and after a carb rebuild it stopped , for some reason the carb was flooding the engine when it was hot
Old Aug 25, 2012 | 11:20 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
First thing to check if its carb: Check the choke to make sure its functioning, and functioning properly. Try adjusting the choke while someone else trys starting it and see if it makes any difference.
Check spark plugs, running too lean/rich?
Check fuel pressure
I dont think its coil, if it was it most likely wouldnt give you the problem only when hot.
Any check engine light/codes?
Old Aug 26, 2012 | 02:47 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Turn over or fire up ?
Two completely different situations
Old Aug 26, 2012 | 02:49 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Wanna bet
Very common for old electrical parts to fail when heated up , but be fine when cold
The ICM inside the dist for example is well known for this.Resistance in a coil can change ( breaking down ) when hot
some reading
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Old Aug 26, 2012 | 04:02 PM
88mauiblue's Avatar
It is an EFI motor no carb
It's not firing, it is cranking though
I'm going to try and replace The ICM and coil and see if that solves my problem
Vetteoz I found the article as well, that's what made me believe it was the ICM
Orr89RocZ
Apr 25, 2016 08:28 AM
db057
Aug 22, 2015 08:17 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
92projectcamaro
Aug 6, 2015 01:20 PM
