New Owner with a question
Old Aug 29, 2012 | 03:16 PM
fire_2869's Avatar
Car: 1987 Formula 350
Engine: L98 TPI 350
I know I probably didn't dig nearly far enough, but I need help.
I have an '87 Formula 350 that has been in my family since it was new. My mother finally gave me the car because it was sitting in a shed. It will start and run, but it is choppy on accelleration, and when I shut the motor off, it will boil over the coolant from the overflow can. There appears to be no coolant in the oil or vice-versa and it isn't smoking.
Any ideas before I start a complete teardown?
Old Aug 29, 2012 | 08:57 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
sounds like a bad head gasket you can do a compression test on all cyl see if there is a drop in them. how many miles how long did it sit?
Posted from Thirdgen.org App for Android
Old Aug 29, 2012 | 08:58 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
also how hot is it getting
Old Aug 30, 2012 | 10:14 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Re: New Owner with a question
"boil over the coolant from the overflow can"
On my camry same prob.
Also the upper hose was hot and bottom cold. Tstat was ok, water pump ok, engine would not overheat strangely enough...
I put on a new radiator cap tho the old one didn't look broken and it fixed it.
FWIW.
Old Sep 7, 2012 | 05:47 PM
fire_2869's Avatar
Engine: L98 TPI 350
The car has 68,000 original miles on it and has sat for about a year this time. I am going to start with thermostat and some other small issues.
I have also been told that the computer in my car is junk and that I should look at replacing it with newer technology.
Old Sep 9, 2012 | 11:48 AM
cjberquist88's Avatar
Car: 1988 iroc z
Engine: 5.0 tpi
Transmission: 5 spd manual
my 88 use to bubble over as well and it turned out to be radiator cap
Old Sep 9, 2012 | 09:22 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Yeah. Think.
Before you go tearing things at random up for no reason:
It's been sitting in a shed. For some time presumably. So start by giving it some love.
Drain and replace any fuel left in it. Do oil and filter change. New fuel filter. And plugs. Check tps. Clean iac. Etc etc. Then see what you've got.
Did it have any bad behaviour when it was parked?
Old Nov 8, 2012 | 08:26 PM
fire_2869's Avatar
Engine: L98 TPI 350
Well, it's been a minute, but here's my diagnosis.
I have a microscopic head gasket problem that was just enough to pressurize the system and they also found a lot of brass in the oil filter. Years of sitting and then being started every six months or so just ate the rod bearings.
2495.00 and 4 days later I have a perfect running, numbers matching '87 with 68,000 original miles on the original rims that I just had to put the second set of tires ever on it.
Old Nov 8, 2012 | 09:26 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Pics? Sounds sweet... I love Formulas!
Old Nov 8, 2012 | 10:21 PM
fire_2869's Avatar
Engine: L98 TPI 350
Pictures will come soon. I have to get it buffed out to see if I can fight the sun fade and I have to replace the rear spoiler. I just can't wait to drive it back out to visit my parents.
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
chazman
Aug 22, 2015 02:01 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
