Bogging/hesitating when accelerating from stop b/c of low idle?
Old Aug 31, 2012 | 06:24 PM
RWO3's Avatar
Car: '84 Camaro Sport Coupe
Engine: 355
Axle/Gears: 3.08
The AC didn't work on my car when I purchased it so I replaced the AC compressor and it works now. However, when the AC is on it will hesitate/bog when accelerating from a stop.
Could this be because of a low idle? My car has no tach so I don't know if my idle is too low but turning on the AC definately changes my idle speed.
Thanks.
Old Sep 9, 2012 | 08:44 PM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Re: Bogging/hesitating when accelerating from stop b/c of low idle?
Sounds like a bad idle stop solenoid or you may not even have one? Check to make sure that the idle stop solenoid on the drivers side of the carb is working. It is what increases throttle when the engine is under load, like the A/C compressor.
http://www.ebay.com/itm/IDLE-STOP-SO...#ht_5549wt_956
Hope that helps!
Chuck
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
perZ
Aug 21, 2015 05:51 PM
perZ
Aug 15, 2015 01:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
