noise when hitting throttle
Old Sep 2, 2012 | 01:27 PM
Wayne91rs's Avatar
1991 camaro z28 carbed v8. There's a noise coming from the front of the car when I step on the throttle and the car moves. But when I take my foot off the gas and the car coasts it goes away. The noise sounds like its coming from the engine area. It sounds like a whirl and gets faster as the car goes faster but again when I lay off the gas it goes away. Any ideas? Thanks for the help!
Old Sep 2, 2012 | 01:31 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: noise when hitting throttle
No idea, I would need to hear it. I suggest you take an experienced mechanic for a ride.
Old Sep 2, 2012 | 02:17 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Do you gave a mechanical fan or electric?
Old Sep 2, 2012 | 02:27 PM
Wayne91rs's Avatar
Mechanical fan
Old Sep 2, 2012 | 02:46 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
Is it a clutch fan or flex. The flex fans do tend to whir. If its a clutch fan, check the clutch. It could be locked up
Old Sep 2, 2012 | 02:48 PM
Wayne91rs's Avatar
It's a non clutch mechanical fan.
Old Sep 2, 2012 | 04:24 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
Do you have any bent blades. Anything in or around the shroud that could be vibrating?
Old Sep 2, 2012 | 04:31 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
Without hearing the noise those are my best guesses. It could be a alt going out. A water pump going bad a. A power steering pump that's low on fluid. Air pump squealing. So on and so forth
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
87camaro87
Sep 9, 2015 10:29 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Randomtask2
Sep 7, 2015 05:06 PM
