engine starts then dies HELP
Old Sep 2, 2012 | 04:12 PM
Kyxxer's Avatar
Car: 1984 Z28
Engine: 355
Axle/Gears: 3.73 LS
my buddies car died yesterday after a cruise through the twisty roads on the way home
problem- car was running fine well running it hard through some twisty roads then shut it off for 10mins started it back up and he was running rough (sounded like 6 cylinders) then a kilometre down the road it slowly died? let the car cool down then tried to start it and it would start up and instantly die about 3-5 seconds later (sounded strong)
A day later it still does the same thing, starts runs for 3-5 seconds then dies no matter if you dont touch gas or floor it (sounds strong)
whats been tried
scanner- no error codes
checked all connections
checked fuses
VATS seem fine on keys
MAF- unplugged to put car in "limp" mode
oil pressure sending unit
fuel pressure seems fine, going to check with a gauge tomorrow
new parts
fuel pump
valves
plugs
plug wires
pretty much a top end rebuild
ANY ideas? anything will help!
Old Sep 2, 2012 | 05:41 PM
T/A's Avatar
T/A
Car: 1990 T/A w/WS6
Engine: 5.7L V8 TPI
Axle/Gears: 3.23 w/ posi
Re: engine starts then dies HELP
according to the firebird service manual, you should check to see if THERMAC is working right.
however the last two, options are to check engine timing, and if the car has bad gasoline...
both seem pretty good to check.
Frozer!!!
Jan 19, 2024 04:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
