383 stroker oil change
Old Sep 6, 2012 | 09:47 PM
Jseb's Avatar
I'm new to the forums, thank you in advance for any advice.
So I bought a 1970 Chevelle with a 383 Stroker motor and decided to do an oil change, which is when I realized how little I actually know about the car.
My first problem was deciding which oil to use (brand, viscosity, conventional or synthetic). I did some research but still could use more advice.
Then I realized that I have no idea how many quarts to put into it. Now, the double-whammy about this is that the dip stick is broken off, so I cannot use that as a guide (but im not sure how much I would trust it even if it was functional). Plus, I've already drained the oil out of it, but measuring the oil that came out of it isnt my preferred method either since I dont trust that it was correct initially (although I did measure it). I've done some measuring of the oil pan and discovered that it was a Moroso oil pan with a depth of 8", which might indicate a 6 quart capacity. However, that does not compare with the amount of oil that I had drained out of the car (which I wont mention as not to alter someones opinion).
I am wondering if there is a sure-fire way of knowing how much oil to put into the car. Thank you for the help.
Old Sep 6, 2012 | 10:02 PM
Damon's Avatar
Re: 383 stroker oil change
Only with a proper dipstick.
Like I have told many over the years, it doesn't matter what pan you have on the engine. The dipstick will tell you how far below the oil pan rail the standing height of the oil should be. It doesn't care how deep or wide the ocean is beneath it, it only tells you where "sea level" shuld be.
A MATCHED SET dipstick. Definitely NOT a tube from one and a stick from another. A NEW dipstick & tube set out of the package that was designed to work together to tell you the truth is what you want.
Old Sep 6, 2012 | 10:46 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
unless your oil pan is enlarged, it should be 5 quarts
Old Sep 7, 2012 | 08:35 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
This isn't 3rdgen related buuut
Posting a pic of your oil pan will help.
Does it look like this?
http://www.moroso.com/catalog/catego...?catcode=11010
Old Sep 8, 2012 | 04:41 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Or does it look like this which is the stock 350 pan
http://www.amazon.com/gp/product/images/B003GUQ3RU/ref=dp_image_0?ie=UTF8&n=15684181&s=automotive http://www.amazon.com/gp/product/images/B003GUQ3RU/ref=dp_image_0?ie=UTF8&n=15684181&s=automotive
Old Sep 8, 2012 | 06:02 PM
Jseb's Avatar
Thanks to everybody for the help! My oil pan is definitely NOT the stock 350 pan. It looks more like the http://www.moroso.com/catalog/catego...?catcode=11010
, although not exactly.
At any rate, I bought a new dip stick and poured 7 quarts of oil in it to get it to the full mark. Here's my pan: http://tinypic.com/r/2u7axcl/6
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
