Can a starter motor get "weak"?
Old Sep 10, 2012 | 12:06 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Battery and charging test good but more and more the engine seems to have trouble turning over like the starter is getting "weak". Does that happen as opposed to it just failing completely? Once started everything is fine.
Old Sep 10, 2012 | 12:09 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Re: Can a starter motor get "weak"?
Ya they can do that, but check your connections at the starter and if all is good with the connections run quickly to the parts store for a new starter.
Old Sep 10, 2012 | 01:31 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Yes of course. The windings will go bad, especially if the starter is stuck out and the engine is spinning it while you are driving.
Easy way to check is turn on your headlights, if the lights dim a whole lot and the starter is cranking slowly you most likely hav an issue with the starter. If the starter cranks slowly but the headlight only dim slightly or not at all could be a problem with ground, or shorting + cable.
That is a vague and primitive way of testing it but it will give you some idea so you can further evaluate it or feel more confident in your decision to purchase a new starter.
I dont know what tools you have available to you for diagnostics, so that way requires nothing.
Old Sep 11, 2012 | 01:26 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
One issue I have with this test is that it doesn't eliminate a weak battery.
On the flip side I was close to calling out a battery on a Ford F150 this summer because the engine would barely crank and when cranking the battery voltage dropped to the floor. Performed a starter draw test and found 1000 amps draw due to a faulty starter. A new battery wouldn't have helped that.
Old Sep 11, 2012 | 01:31 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Even if you take it to Autozone or Advance they will test it and that isn't a foolproof test but it doesn't hurt.. ASE Doc was correct about the draw down test..
Old Sep 11, 2012 | 03:49 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
The bench test that they do at the parts store is an "unloaded" test. It will only prove that the motor activates and spins with no load placed on it. This is a completely different situation than being installed in the vehicle and trying to turn an engine.
Old Sep 11, 2012 | 03:51 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
I surprised that didn't melt the leads!
Old Sep 12, 2012 | 02:37 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Yeah, and only a big bad battery like the yellow top Optima could have supported that kind of current. Fortunately, we looked at starter current right away before we tried cranking the engine too much.
Old Sep 12, 2012 | 04:39 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I checked battery voltage at the starter and the switch wire and they were ok so I pulled the starter and bench tested it. It was fine so I put it back in and it all works fine. I cleaned all contacts so it was likely that but nothing looked bad enough to cause the problem. All's well that ends well. Thanks for the suggestions.
mhatfield 14
Oct 24, 2015 07:48 AM
5spdcamaro
Aug 28, 2015 02:12 AM
Wesly_66
Aug 26, 2015 09:55 PM
Cleotiz
Aug 22, 2015 01:54 PM
milk
Aug 10, 2015 06:26 PM
