Fuel pump this or that?
Old Sep 11, 2012 | 09:47 PM
Facekill88's Avatar
Car: B4C
Transmission: Man 5
I have bigger inj so i want to replace my pump before i brun it out so what is better? this one http://www.ebay.com/itm/255-LPH-HIGH...5cf264&vxp=mtr or that one http://www.ebay.com/itm/255LPH-High-...97f634&vxp=mtr
Old Sep 13, 2012 | 09:56 AM
Facekill88's Avatar
Car: B4C
Transmission: Man 5
Re: Fuel pump this or that?
To the top
Old Sep 13, 2012 | 04:32 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Facekill88
I have bigger inj
Why?
What have you done to your 305 to need bigger injectors?
What makes you think you will burn it out on a 305?
Both those pump are no name ; you get what you pay for
and given the trouble needed to replace the pump in a 3rd Gen ( if you don''t cut a trapdoor ), I would be looking at a better quality that may last longer
Old Sep 14, 2012 | 01:03 PM
Facekill88's Avatar
Car: B4C
Transmission: Man 5
The next thing im do is a cam, so im looking to find the better choice on the fuel pump.
Old Sep 14, 2012 | 02:50 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
As vetteoz just asked, why did you install bigger injectors? Unless you've made modifications to the motor that significantly increase air flow, the larger injectors are just going to flood the motor with fuel.
Old Sep 15, 2012 | 10:21 AM
Facekill88's Avatar
Car: B4C
Transmission: Man 5
Oh, okay so would a port and polish help? And if i put a ram air in take on would that give it the air it needs?
Old Sep 15, 2012 | 01:36 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Do yourself a favor and do a LOT of research before you start buying parts. You'll save a TON of money. Look into doing a full headers back exhaust before you do anything else.
Old Sep 15, 2012 | 01:46 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Until you make serious changes in your engine for it to be able to make use of more air or fuel you will only spend money bogging it down. It needs to be able to breathe more before you go shoving fuel down it's throat
Old Sep 15, 2012 | 02:40 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
FYI: here is the place to get your fuel pump, when yours dies. Order it now if you want but no need to put it in until yours goes out.
http://www.racetronix.com/
Old Sep 15, 2012 | 09:01 PM
robeil3062's Avatar
Car: 1988 iroc-z
Engine: 350 tpi ,5.7
Axle/Gears: got me
get a 350
Old Sep 17, 2012 | 10:53 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
I would have to agree that this is the key to success. Before you spend another dime on parts that may or may not help, do some reading. HP Books is one source of great info on building the small block chevy for power. The internet can be another. Your basic stock TPI will support an additional 100HP over stock with the right modifications. It all starts with heads and cam, then you can port the base manifold or just install a hi flow base and runner set. Headers and free flowing exhaust finish off the combo.
Most of the parts that will make power from a 350, will also work on your 305. The 305 just has to spin faster to make the power. Also, the 1/4" smaller bore(3.75 vs 4.00) is a restriction to max power capability. The main point is, power begins inside the motor, not with what's bolted onto it. All the bigger injectors, fuel pumps and air intakes in the world will not make your stock headed, stock peanut cammed B4C make real power. Remember also, when you do put together the heads cam, intake, exhaust and fuel system to make the power you want, you will be beating up on the stock rotating assembly and unprepared factory block. I never build a hot motor without first having a good machinist check, measure, align, balance and blueprint the block and rotating assembly and assemble the rods with good pistons. The $1000 you spend at the machine shop is worth a fortune of insurance every time you hit the 6,000+rpm rev limiter.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
