some 383 questions
Old Sep 20, 2012 | 08:12 PM
gkempf's Avatar
some 383 questions
Hello everybody, i'm new here. Great site and a lot of good info I have found here. I recently got a 91 rs lo3 305, Been wanting a camaro since I was just a wee little lad. So I now I got one time to start making it faster lol.
Proubly gonna put 3:73 gears in it, just gonna be a street car. Something to get out once in a while and burn some rubber with. Which brings me to my engine build.
Here is what I got.
I have a 350 out of a 98 chevy that I spun a rod bearing in, I"m gonna make it into a 383 I already ordered the Eagle 383 kit (crank, rods, pistons, and bearings). Got the performer rpm intake, and I have a 780 holley but I think it may be to large.
So I'm just wondering from you guys expierence what cam and headwork I should have done and if that carb. is way to big or not. Oh yeah I wanna keep it running on pump gas.
Old Sep 20, 2012 | 09:03 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: some 383 questions
Buy SCAT, I have had nothing but luck with them. Eagle on the other hand....
Heads/cam depends what you are wanting to build, drive ability, and much more. It's hard to make a suggestion really. One guy might call a 4,500 stall converter behind a motor that spins 7,500 streetable while another might call a 2,000 stall spinning 6,000 RPM streetable.
Old Sep 20, 2012 | 09:10 PM
gkempf's Avatar
It's not some thing i'm gonna get it and drive 100 miles away, or even 50 for that matter. I have the vortec heads so I wanna use them since I already have the intake that will fit them, Would like to be in the 400hp range. I also want a cam that has a pretty ruff idle(I just love the sound of them). A stall around 1800 was what I was thinking but I dont really know.
Old Sep 20, 2012 | 09:12 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Try http://www.camquest.com/
That's CompCams Camshaft Selection site. Big thing is don't go over board on camshafts. A super lumpy one without the correct setup will run like crap. A peanut one like the OEM one in a built motor will run like crap.
Performer RPM Intake I believe is low to mid RPM so you're not going to want one with crazy lifts and duration like you would see on a Victor setup.
Pump gas is more defined by the compression of the pistons (which comes from your pistons, heads, and head gaskets) then figure in how much timing you plan on running.
Anyway play around with that you'll find some cool information. There are way too many missing variables.
Is this a Manual or Automatic? Which Transmission?
What compression ratio is your kit?
What heads are you looking at? Aluminum or Iron? What valve sizes? What CC rating?
Which type of camshaft are you going to run?
Old Sep 20, 2012 | 09:14 PM
Engine: 383 SBC
A stock 350 TPI is good with a 2400 RPM flash speed. That's what I had on my 9" converter with the 700-r4. It loved it. Again it just depends on the setup. My new motor likes more of a 3k+ RPM flash speed.
Old Sep 20, 2012 | 09:18 PM
gkempf's Avatar
Trans is a 700r4. Heads are vortec casting no. 12558062.
Old Sep 20, 2012 | 09:30 PM
Engine: 383 SBC
Yeah sorry about that you guys must have posted while I was typing before.
Do you have a 10 bolt or a 9 bolt rearend? When swapping gears plan on 500 to 1000+after you get parts and labor. Cheapest place here wanted 300 labor highest was the dealership at around 700 to 800 labor.
Old Sep 20, 2012 | 09:32 PM
gkempf's Avatar
I have a buddy that with do the labor of putting them in for a few beers lol. I also thought about just buying a whole rearend out of a 4th gen from a junk yard.
Cameeeero
Sep 18, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
