pressure hose for aftermarket power steering pump?
Old Sep 20, 2012 | 08:34 PM
mikeirocz1's Avatar
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
I have a tuff stuff power steering pump for old school chevy on my 88 IROC-Z and it has inverted flare fitting and the stock hose is O-ring. Does anyone know of a hose that will work with the stock box and aftermarket pump? I need O-ring for the box and inverted flare for the pump.
Old Sep 21, 2012 | 06:33 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: pressure hose for aftermarket power steering pump?
For awhile NAPA was making those hoses, come to think of it that was fifteen or twenty years ago. I due believe there is an adapter out there that goes in the box so your hose will work. I don't have the link but with a little searching I think you will find it. Good luck.
Old Sep 21, 2012 | 06:52 AM
Shouldn't be too tough to cut the O-ring end off the line and flare it. As long as there's a long enough straight section behind it to get the new flare nut and flaring tool onto it at the same time.
Old Sep 21, 2012 | 10:20 AM
mikeirocz1's Avatar
Could I just cut the o-ring end off and use the stock nut on the hose and flare the line? Or do I have to use a special nut? I thought about trying to get the fitting that screws into the back of the stock IROC pump that the hose screws into and putting it on the aftermarket pump but I'm not sure if the thread size is the same where it screws into the pump. Does anyone know the thread size for the fitting that screws into the back of the stock pump?
Old Sep 21, 2012 | 04:26 PM
Edwardgp's Avatar
Engine: 454-350
http://shop.hoseandfittings.com//
Old Sep 21, 2012 | 08:16 PM
mikeirocz1's Avatar
I got the fitting from the back of the stock pump and put it in the aftermarket pump. Thanks for the help!
Old Sep 22, 2012 | 08:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, I was just going to post that you can swap the fittings between the two pumps. BTDT.
RBob.
Old Sep 25, 2012 | 12:00 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
http://www.pirtekusa.com/
There ain't a hydraulic hose they can't make.
92camaroJoe
Jul 29, 2023 07:57 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
92camaroJoe
Aug 13, 2015 06:07 AM
