What is your gas mileage?
Old Sep 23, 2012 | 01:31 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
Just a question to ask everyone. I'm curious to see what everyone is getting either stock or with mods.
I've heard a couple people say they average around 23 or 24 on the highway with their L98, and i get around 15.. kinda bothers me
all i have is cold air intake, edlebrock headers, 3in exhaust, no cat, 180* tstat. and i get between 12 and 15 in town or highway..
so what do you guys get?
Old Sep 23, 2012 | 01:36 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: What is your gas mileage?
We've done plenty of these threads. Do MORE searching. You didn't specify your MPH, nor your axle ratio, nor your elevation.
Old Sep 23, 2012 | 02:00 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i get around 12 in town/20-22 hwy from my mild-mods 350 crossfire/700r4/3.42 rear
Old Sep 23, 2012 | 03:27 PM
ex-x-fire's Avatar
Well w/ a cold air intake, full 3'' exhaust, headers, & a 180* stat, its no wonder the mileage is low. Try a 195* stat & see if your mileage improves.
Old Sep 23, 2012 | 03:29 PM
Engine: 350 L98/LS2
i did a search with gas mileage in the search box, looked through 2 pages worth and didn't find what i was looking for.
also my axle ratio is located in my sig AND on the side under my profile pic
Old Sep 23, 2012 | 03:31 PM
Engine: 350 L98/LS2
thing is that my mileage was about the same with a 195* installed. only reason i did a colder one is that i needed to replace it and had this one on hand already
Old Sep 23, 2012 | 07:25 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
I get 16-18 in city, with a mostly stock 5.7 (no smog pump, headers, and spectre cold air intake) but I like to get on it a lot. Could see getting around 20 if I really babied her. Haven't checked it on the highway. I was getting 10-12 before I replaced o2 sensor though, I would check that first.
Old Sep 23, 2012 | 07:38 PM
Engine: 350 L98/LS2
My CEL would be on though wouldn't it?
Old Sep 23, 2012 | 08:05 PM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
I get around 22-27 mpg on the highway and around 15-17 in town.
Old Sep 23, 2012 | 08:19 PM
fervernt's Avatar
Not neccessarily, no. If its failing, but hasn't given out yet, there wouldn't be a code. These sensors weren't designed to last all that long, and its a fairly cheap one (around $20) so id just replace it and see what happens. Other then that, a basic tuneup can work wonders too.
Old Sep 23, 2012 | 08:26 PM
Engine: 350 L98/LS2
I did a fairly basic tune up this year when i had the engine out and replaced seals and gaskets. Replaced plugs and wires and timed it. I should probably do a fuel filter at some point.
It does seem like the car runs fairly rich though most of the time.. and even before i removed the engine it seemed to run a little rich.
Old Sep 23, 2012 | 11:10 PM
fervernt's Avatar
Running rich is leading me to think possibly o2 even more.
Old Sep 24, 2012 | 02:30 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
If your fuel filter has never been replaced, DO IT NOW! So many times I've seen a new fuel filter really, really helping out a car over a clogged one.
Old Sep 24, 2012 | 02:45 PM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Haven't replaced the fuel filter in my '92 Z28 in about 5 years, car is currently Sitting in my garage in Retirement, till I can afford the gas & expenses to fix a few minor things, some tlc, but last I drove it was getting 16/18 city & 24/26 hwy when I really drove it as if it were a Minivan, absolutely NO hard takeoffs no sudden braking or hot rodding off the green lights or Blowing by everybody else on the Freeway, it got what I consider good mpgs and I didn't have to abuse it. But when I first got it that I spent a weekend just Roaring thru the Streets and Freeways of L.A. I got maybe about 8 mpg in the city and 12 on the Hwy
Old Sep 25, 2012 | 12:36 AM
Engine: 350 L98/LS2
I've only owned it 2 years. I haven't changed it. Not sure when it last was
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Glowsock
Sep 11, 2015 11:09 PM
