Heat coming from Gear Shifter and smoke with no overheating
Old Sep 26, 2012 | 04:33 AM
Heavy Arms's Avatar
Car: 1983 Z28 Camaro
Engine: 355 0.60 Bored
I have started to notice that when driving my 83 Camaro, One I have noticed that I can feel heat coming up from my gear shifter. I also noticed that when I arrive at a destination from driving in the camaro, I can smell smoke in my shirt and i'm pretty sure its coming from the heat from the gear shifter. You cant see any smoke or anything like that but putting your hand over the shifter, you can feel the heat. Also after driving for a while, smoke comes from the left side under the hood but the car isnt running hot or anything like that. Could this be a problem in my exhaust system or something?
Old Sep 26, 2012 | 05:31 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Heat coming from Gear Shifter and smoke with no overheating
To me it sounds like oil dripping onto your exhaust manifolds. I would take a close look at your valve cover gaskets and surrounding area,
Old Sep 26, 2012 | 09:11 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Old Sep 27, 2012 | 01:08 AM
Heavy Arms's Avatar
Theres no oil dripping from what I see...my motor is fairly intact no drips or leaks from anything for the most part. Only thing I figured is my camaro is lowered and sometimes if I hit a bump too hard or go over a speed bump the bottom of my car will scrape. Could it be that that may have put a crack in one of my exhaust pipes or sumthin and its smoking? I dont know i will check the oil dripping suggestion a lil more thorough again tomorrow in the light.
Old Sep 27, 2012 | 01:10 AM
Heavy Arms's Avatar
So that oil dripping thing can cause the heat to come through the gear shifter though??
Old Sep 27, 2012 | 08:44 AM
Edwardgp's Avatar
Engine: 454-350
When you get the first problem figured out you should seal up things under your console.
mustangman65_79
Sep 1, 2015 03:51 PM
NBrehm
Aug 25, 2015 11:49 PM
jbd1969
Aug 17, 2015 07:06 PM
Fronzizzle
Aug 17, 2015 02:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
