How to drain gas
Car: 1988 Black GTA
How to drain gas
So I have been doing a lot of reading on this site and I can see there are a few things to do to my 88 GTA that I recently got. One of which is drain the gas. Not to sound like an idiot but what is the best way to do that?
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: How to drain gas
Siphon it out with a hose. Don't suck on the end of it for obvious reasons. Unless you like drinking gasoline.
They sell hoses with those primer bulbs on them. I have a siphon hose that has a little copper rattle-ball-thingy on the end that acts as a primer:
http://www.boatshowproducts.com/super-siphon-hose
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Disconnect the fuel line under the hood, power up the fuel pump via the relay and siphon it out.
Car: 1988 Black GTA
Car: '87 IROC
Engine: LB9
Seafoam or injector cleaner wouldn't be a bad idea. Replacing the fuel filter before filling the tank with fresh fuel wouldn't hurt either.
Car: 1988 Black GTA
Car: '87 IROC
Engine: LB9
Use flare nut wrenches for the fittings. If there's corrosion spray the fittings with penetrating oil like PB Blaster before trying to loosen them. don't lose the o-rings that are on the lines. Don't over tighten the fittings.
Car: 1988 Black GTA
Under the car on the driver's side in front of the fuel tank.
Car: 1988 Black GTA
89 formula TPI
Sep 7, 2015 11:06 AM
