single or dual plane intake?
Car: 86 firebird t/a
Transmission: auto
Axle/Gears: stock
a stock 305 which would be better for performance a single plane or dual plane? whats the difference between them? thanks
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: single or dual plane intake?
Dual. There really isnt even a debate here between the two.
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Dual for sure. The dual plane splits 4 cylinders per level. The single has all plenums connected to a common area under the carb. Dual works better with lower RPM, single with higher...then you have the smaller displacement of the 305...go dual.
http://forum.grumpysperformance.com/...hp?f=55&t=5510
read thru this and its sub links
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Thanks!
Chuck
A totally stock 305 as you know is rather pathetic in both head flow and cam timing and most have restrictive exhaust. that doesn,t mean the engines hopeless , only that you need to think thru your choices carefully, Ive normally seen better results when both the intake and cam are upgraded, a common combo of well matched parts for a 305 is
http://www.summitracing.com/parts/CMB-03-0113/
http://www.cranecams.com/product/car...detail&p=23759
THESE HEADS WOULD REALLY HELP
http://www.summitracing.com/parts/TFS-30300001/
the combo of intake and cam alone, is usually worth about 30-35 hp, which is a darn nice gain, the intake alone is probably worth 10-15hp, but its going to be worth more as the cam and heads are upgraded to flow more also, because its not nearly as restrictive as the stock intake.
the heads plus intake and cam should easily be worth 50-60hp minimum. but before you go throwing cash into a 307 you might just want to save up and build a 383-406 SBC that has more potential.
these links and sub links should help
http://forum.grumpysperformance.com/...uilding#p18253
http://forum.grumpysperformance.com/...php?f=69&t=519
http://forum.grumpysperformance.com/....php?f=55&t=58
http://www.airflowresearch.com/artic...le115/A-P1.htm
Definetly a balancing act between cost/performance issues when dealing with the 305. Thanks for the info!
Chuck
Chuck
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The OE intake manifold is a dual plane. The dual plane intake divides the runners into 1/2 long, 1/2 short to extend the engine's torque curve. The dual plane design favors low and mid range torque production. Most DPs are designed for engines making peak power below 5,500. Some performance versions like the Performer RPM have been optimized to support power up to 6,500rpm.
As a general rule, you want to use a dual plane intake for any engine that makes peak power below 6,000rpm and is used mainly on the street. The single plane manifold is for an engine that makes peak power above 6,000rpm and where a long flat torque curve with optimal high RPM horse power power is the goal. Keep in mind that in most high performance engine builds, a performance dual plane intake will produce better average torque than a single plane even though it may reduce peak power slightly.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
