89 Camaro Stalling Issues
Old Oct 10, 2012 | 03:17 AM
Blue_Thunder_89's Avatar
Car: 1989 Camaro Custom RS
Engine: 305 V8 TBI
Transmission: 5 speed T5
Axle/Gears: 3.23 posi
Ok first off I had this problem happen last year. The car used to stall out on me randomly but now its got a pattern. Back then I replaced the IAC, TPS, temp sensor and made sure everything was clean. It seemed to fix it. The car is a 305 with TBI.
Now after the first day of cold I go to start it in the morning and it starts up but after a few seconds it dies. After restarting a few times it appears that something finally gets warm and it starts running ok.
Another problem I am having is that once it is warm it will sometimes stall on me when idling after either the fan comes on or I start rolling up a window. While idling any extra load on the electrical system makes my voltage severely drop and sometimes will make the car stall.
Any help?
Old Oct 27, 2012 | 11:48 PM
Engine: 305 V8 TBI
Re: 89 Camaro Stalling Issues
Ok so I have done this test where you let the car warm up and then idle. From there you turn the head lights on and the heater full blast and it causes the car to stall.
Any ideas on this would really help me out about now.
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
