Stalls at idle
Old Oct 10, 2012 | 02:08 PM
johntaylorny's Avatar
Stalls at idle
1984 Firebird 2.8L V6
Warm weather
Car starts up just fine but once RPM drops to idle the idle gets really ruff and then the car stalls. It doesn't always happen. Sometimes idle is just fine and car hummmms. Even after driving and engine warm sometimes car stalls at idle. My mechanic says "just give it gas" well that works obviously and prevents the stall but it's not a fix to the problem.
Any ideas what's going on?
Old Oct 10, 2012 | 08:06 PM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Re: Stalls at idle
How is you low speed (base) idle set? It may set too low so when the engine is warmed up like you mentioned, the carb throttles down to whatever the low speed idle is set to. the low speed idle is located on the driver side, front part of the carb where the throttle linkage is attached to the carb.
Hope that helps
Chuck
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
rjcme
Sep 5, 2015 01:23 PM
