should i get these cylinder heads?
Old Oct 11, 2012 | 10:54 PM
cinder41's Avatar
Car: 1988 Firebird
Engine: 350 TBI
Transmission: Th700R4
Axle/Gears: 3.27, 9 bolt Borg-Warner
Alright I found these Dart 10024360A cylinder heads with 165cc intake runners, 76cc combustion chambers, 1.94 intake and 1.50 exhaust valves. Are these heads good to get with my set up.
Right now i have a 350 TBI with GM performance zz4 intake, headers and exhaust, lt1 cam, oh the block been bore to .040, and it has the stock heads.
I found them on craigslist and he asking for $475 for the pair should i jump on it or wait?
Old Oct 11, 2012 | 11:00 PM
gp90gta's Avatar
Car: 1990 GTA
Re: should i get these cylinder heads?
Whats you deck hight and what piston did you use?
Old Oct 12, 2012 | 12:42 AM
cinder41's Avatar
Car: 1988 Firebird
Engine: 350 TBI
The deck hight standard and using flat piston.
Old Oct 12, 2012 | 09:06 PM
cinder41's Avatar
Car: 1988 Firebird
Engine: 350 TBI
So what would i need to get to make these heads work with my block?
Old Oct 12, 2012 | 09:23 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Eh I think I would pass. It will drop your compression ratio down a lot. Theyre not really that great that they would offset your loss in compression.
Old Oct 12, 2012 | 09:59 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
pass
Old Oct 12, 2012 | 10:17 PM
cinder41's Avatar
Car: 1988 Firebird
Engine: 350 TBI
so im just better off with the stock heads then
Old Oct 12, 2012 | 11:03 PM
cinder41's Avatar
Car: 1988 Firebird
Engine: 350 TBI
What would you guys recommend for my set up but I'm on a budget
thanks for your help
Old Oct 12, 2012 | 11:58 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Afrs and bigger darts would be best, Trick Flows are great I have them. Patriot and RHS make reasonably priced aluminum heads. Or see if you can find some Chevy aluminum heads vette style.
I think the Dart Heads you are looking at are for a 305.
Old Oct 13, 2012 | 01:18 AM
gp90gta's Avatar
Car: 1990 GTA
Look for a set of aluminum heads, anywhere from 180-190cc runners of even 195's if you plan on changing the cam, also shoot for a 64-65cc chamber, this would give you some okay compression, my guess would be somewhere about 9.3-10.1 depending on the compression height of the piston.
The reason I asked about deck and piston was to get an idea of what you compression would be with a 76cc chamber, its not that you cant go with larger chambers its just that you would need a cam that would give you much more dynamic compression, these days no one runs large chambers anymore plus a 165cc runner is on the small side for a 350.
I would hold out save some more money and look for a head that would best fit your application,, I've seen good used heads for $700-800 that would be a much better fit.
Old Oct 13, 2012 | 05:58 PM
cinder41's Avatar
Car: 1988 Firebird
Engine: 350 TBI
Alright thank for the advice guys. What about runners of 200cc is that fine or would that be to much? Im sorry for the dumb questions Im still learning about this stuff
Old Oct 13, 2012 | 06:13 PM
ex-x-fire's Avatar
Check out the vortec heads, you'll need a matching intake though.
Old Oct 13, 2012 | 07:45 PM
cinder41's Avatar
Car: 1988 Firebird
Engine: 350 TBI
Actually I've been checking out the Vortec heads Is it worth the investment?
Old Oct 13, 2012 | 08:20 PM
gp90gta's Avatar
Car: 1990 GTA
The Vortec head are good if your on a real tight budget, they'll be fine with the lt1 cam you have but if you plan on a cam change in the future you will be limited on lift unless you do some work to them, your intake won't work though so keep that in mind.
Old Oct 14, 2012 | 02:43 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i'd get the heads.. the 76cc chambers will give you about 9:1 compression ratio with the flat top pistons and a .015 shim head gasket.
ask if you can get a guarantee that you can take them to a machinist and get them checked for cracks and warpage and get your money back if something is wrong with them. if not, offer $100 less.
you aren't going to find any better heads for less money unless someone sells you a set of vortecs with upgraded springs and the matching intake and what not for the same price..
Cornholio7979
Sep 20, 2018 02:31 AM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
