What exactly does this mean...?? =P
Old Oct 15, 2012 | 08:37 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So on my LG4 84 Z28 I removed spark plug #2 and this is what it looked like....when I smelled it it smelled like gasoline.....PS...I am also going to change plugs but just wanted to know why exactly this means....thanks!
and PS.....The plug was a little loose and I was actually able to remove it by hand....no ratchet..
Old Oct 15, 2012 | 09:10 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: What exactly does this mean...?? =P
The plug was not firing and because it was loose, you have blow by on the plug. Make sure you clean the threads out in the head so the plug gets a good ground.
Old Oct 15, 2012 | 09:12 PM
calgutie's Avatar
Car: 1984 Z28
alright will do...but you don't think its anything major??that's the only thing that worried me...
Old Oct 15, 2012 | 09:50 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
wow that's a decent amount of gunk on there. Definitely clean the threads, check the wire on that plug, check the cap and rotor, too. are any other plugs like that?
Old Oct 15, 2012 | 11:03 PM
calgutie's Avatar
Car: 1984 Z28
well as for other plugs IDK yet I just happend to remove this one but I will check.
Old Oct 15, 2012 | 11:54 PM
GTAman's Avatar
i highly recommend you check them all. you want to make sure you don't have a bigger problem. it could be as simple as replacing some ignition tune-up parts or deeper like a leaking injector(s). how has the car been running up until now?
L695speed
Apr 6, 2013 11:14 PM
herders
Nov 12, 2012 11:36 PM
mitchberry
Nov 8, 2012 10:11 PM
onthedownlow
Aftermarket Product Review
May 4, 2011 11:15 AM
88fastgta
Dec 5, 2008 02:29 PM
