Replace distributor for non ccc carb.
Old Oct 15, 2012 | 07:27 AM
djjon76's Avatar
Car: '84 Trans Am
Hi all.
I know for a fact that the carb I have on my engine is from a '79 engine and must of been replaced here in Aust and isn't ccc.
Anyway, from what I can see they didn't change the distributor. I don't see any vacuum advance on the disty. The car does run, but does smell very rich.
I've attached photos of the dist if that helps to identify it.
Is there a guide or a disty that people recommend to replace the ccc one?
Cheers.
Size:  126.7 KBName:  20121015_221249_zpsed446f9f.jpg
Old Oct 16, 2012 | 03:13 AM
djjon76's Avatar
Car: '84 Trans Am
Re: Replace distributor for non ccc carb.
Anyone?
Just need to know what Disty to change to and if there is a guide on how?
Cheers.
Old Oct 16, 2012 | 04:33 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Any earlier model hei with a vaccum advance from bone yard or spend for a new DUI hEI vaccum advance dizzy.
Old Oct 16, 2012 | 06:07 AM
djjon76's Avatar
Car: '84 Trans Am
Cool. Stupid question of the day..... Where does / can the vacuum advance connect to?
Old Oct 16, 2012 | 08:28 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Either to a ported vac source above the throttle blades, or directly to full manifold vac. One of those 'two schools of thought' things. Prefer full manifold myself.
Old Oct 16, 2012 | 08:51 AM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
The vac advance for the distributor gets hooked up to a part vaccum source not full vaccum
Old Oct 16, 2012 | 09:09 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Yep, full. Gives you slightly better idle, mpg, and lower temps.
Edit: Use in conjunction with an adjustable can, so you can dial it in right.
Derick15
Sep 17, 2016 05:28 PM
86IROC112
Aug 17, 2015 07:57 PM
Street Lethal
Aug 13, 2015 08:28 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
