what motor 3.75 3 1/2 stroke
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Re: what motor 3.75 3 1/2 stroke
I calculated 309ci. But I think that 3.5 stroke is more like a 3.48, which would make it your run of the mill 305. That is unless it is stroked .02".....
You need to specify a little better, maybe some background on what you are specifically asking. I assume you mean 3.75 inch bore and 3.5 inch stroke. I think what you are asking about is a 305, 3.736 inch bore and 3.48 inch stroke.
But with piston saying .40 .40 over?Has some other numbers on the pistons to.
Can see that it has been rebuilt.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's a 305 bored .040 over. The bore is 3.775" and the stroke is 3.48", but you're not using measuring accurately enough to tell.
Engine: 383 Carb
Transmission: 4L60
You don't have to do anything to find out, because it doesn't.
Originally Posted by Apeiron
(pi * (3.75" / 2)^2 * 3.5") * 8 = ?
In english? lol
In english? lol
A .040" over 305 is about a 312.
Not enough different from what it started out as to be any kind of noticeable, in and of itself.
What's 80 cubic inches between friends, anyway?
Stock 305 is 3.736 bore with a 3.48" stroke. So 40-over is 3.776, like was said above. It also means the engine is already on it's 3rd life (stock bore, 30-over and finally 40-over). I wouldn't try 60-over with a stock block, nor is it cost effective to go through all that work when you could just build up a 350 (4" bore block) for the same money. A subject that has been argued to death on this board and many others.
theshackle
Sep 17, 2020 08:26 AM
LT1Formula
Aug 20, 2015 09:36 PM
