Aluminum head questions, J&C cylinder head exchange
Old Oct 22, 2012 | 08:15 PM
datraum's Avatar
Car: 91 Camaro RS
Engine: 383ci, Holley 750cfm carb
I found a set of aluminum heads on Ebay, http://www.ebay.com/itm/360490712702...84.m1423.l2649
I was wondering if anyone has used them before. Also, I have to use the accel short spark plugs on my iron straight plug heads to clear the headers, will the angled plugs allow me to run regular length plugs?
Old Oct 22, 2012 | 09:26 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Aluminum head questions, J&C cylinder head exchange
Headers designed for straight plug heads often do not clear the plugs on angled plug heads because the pipes can be at different angles ;
regardless of what plug type
Depends on the header design
Old Oct 22, 2012 | 10:19 PM
datraum's Avatar
Car: 91 Camaro RS
I have a 383ci, edelbrock performer rpm intake, holley 750 cfm carb and a comp cam with a duration of 287 intake 305 exhaust and .489 intake .476 exhaust lift. I dont race the car I just want it to run and sound good on the street. do you think the 2.05 intake valve and 200 cc intake runner will run ok or should I go with 2.02 intake and 185 cc runner?
Old Oct 25, 2012 | 10:51 AM
hpete's Avatar
It looks like their selling engine quest heads, their cast in Australia, pretty good heads. You should verify that what I'm saying is true before you spend any money. I'd go with the smaller choice for your application, also springs that handle .650 lift will be too stout for a flat tappet cam. Again you need to find out from the seller what the spring rates are and compare it to what your cam grinder recommends.
Old Oct 25, 2012 | 11:55 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Ask questions of the seller! It looks to me like that's $639 EACH. That would not be a good deal for basically stock performance. If anything, the larger valve sizes will be a detriment to performance because of cylinder wall shrouding.
Old Oct 25, 2012 | 03:20 PM
datraum's Avatar
Car: 91 Camaro RS
The heads are made by prostar, and I would use the springs that came with my cam kit. It's $639 for the pair, I'm not really looking to build an all out race engine but then again I don't want to get beat by Hondas. I want the aluminum so I can polish them.
Old Oct 25, 2012 | 09:00 PM
hpete's Avatar
I don't know anything about prostar, they might be great or maybe not. Whatever you choose bore shrouding is not problem with a 4" bore and 2.02 or 2.05 valves. Does it exist? Yes Is it a problem? No
Old Oct 25, 2012 | 09:50 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
They just look like another set of pro comps to me.
Vintageracer
Jan 10, 2020 05:33 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
