e3 plugs and smog
Old Oct 23, 2012 | 08:00 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
e3 plugs and smog
ive heard from a smog tech that e3 plugs actually hurt the chances of passing smog, but ive heard on tv and online that those plugs are supposed to help reduce emissions? anyone actually have done side by side tests or passed with them?
Old Oct 23, 2012 | 08:16 PM
Re: e3 plugs and smog
If the weight of your wallet can affect emissions, then maybe those plugs can invoke that effect.
The fuel either burns, or it does not. Have you ever lit a fireplace? Does the fire burn hotter or more completely if you start it with a match compared to a lighter or even a MAPP gas torch? (that's what I often use because I'm lazy) Sure, it might start up faster; but is the burning of the logs more COMPLETE?
Keep your money in your pocket. The ONLY WAY those plugs will decrease emissions, increase gas mileage, or ANYTHING ELSE, is if they are replacing worn-out ones. In which case, regular stock replacements will accomplish THE EXACT SAME THING.
Old Dec 19, 2012 | 03:10 AM
ajslay's Avatar
Car: 1985 berlinetta
Engine: 305 carbureted
Transmission: 5 speed from a '97 trans am
no ive used those plugs, and there great. even for 5 bucks each, a little better power and mileage. i think about 10hp, and 2mpg. its what i use in all my vehicles. my 350 benefited from these.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
