Configuration?
Old Oct 29, 2012 | 05:35 PM
EJHeavey's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Configuration?
Every engine bay pic I have seen of a third gen anything has the AC compressor on the passenger side and the alternator on the driver side. My 87 IROC is opposite. Anyone got a gander as to why?
Old Oct 29, 2012 | 05:41 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Configuration?
88 was first year to swap A/C compressor to the passenger side. Makes for shorter A/C hose plumbing,and while they were at it, also redesigned the belt drive to be single serpentine.
Old Oct 29, 2012 | 05:53 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Configuration?
How about this one then?
Old Oct 29, 2012 | 07:16 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Configuration?
Some Six bangers got it on the driver's side too . Like my 89 bird here ...
Attached Thumbnails Configuration?-firebird99.jpg   Configuration?-firebird101.jpg
Old Oct 29, 2012 | 08:21 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Configuration?
My 86 has the belts and ac/alt handing as per Vette's pic above. From what I've read, 86-87 were transition years from v-belts to serpentine.
Old Oct 30, 2012 | 07:59 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Configuration?
No, 88 was the first year for serpent belts on v8.
Old Oct 30, 2012 | 04:22 PM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Re: Configuration?
Not tryin to thread jack but has anyone swapped their alternator to the passenger side after removing the compressor and smog pump? I removed mine and now i feel i need the alternator on the passenger side to balance the look of the engine.
Old Oct 30, 2012 | 08:30 PM
EJHeavey's Avatar
Re: Configuration?
Is there a kit or something to swap them sides and use a serpentine belt?
Old Oct 30, 2012 | 08:50 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Configuration?
https://www.thirdgen.org/forums/afte...rsion-kit.html
