Winters coming need to drain water out of motor help..
Old Nov 8, 2012 | 12:13 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
I built a new motor this summer droped it in the car during the fall and havent got it running yet im worried i wont be able to get it running by the time its freezing day and night, i put all water in the block and radiator no anti freeze at all was told to do that incase theres leaks its easier to clean up. Im now worried about cracking the block if a freeze plug doesnt push out is there any way i can drain all of the water outta the block so i can put a 50/50 mix in threw the water neck to replace it... im think i have 3 weeks before its freezing 24/7
Old Nov 8, 2012 | 01:15 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Winters coming need to drain water out of motor help..
There are two drain plugs on the block. One on each side, center bottom, near the pan rail. The passenger side will have the knock sensor in it, the drivers side has a standard pipe plug in it.
The freeze plugs aren't there to save an engine in the event of the coolant freezing. They are there to plug the holes from having to hold the cores in place while the block is being cast.
RBob.
Old Nov 8, 2012 | 02:12 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
You can also drain it most of the way out from the radiator valve, put in concentrated antifreeze and run the motor to mix it with the water.
Old Nov 8, 2012 | 03:50 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
See, that's the problem, He hasn't gotten it running yet????
Old Nov 8, 2012 | 11:53 PM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
i have had it running for maybe 10sec and thats it..ive pulled the bottem radiator hoze and some water came out but by the pouring anti freeze in there i dont see how its gonna mix threw out the block
Old Nov 9, 2012 | 06:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Um, the block drain plugs? Being a new engine they should be easy to remove.
RBob.
Old Nov 10, 2012 | 04:17 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
If it cranks, drain all you can out, fill it with coolant and then crank it a few times. That will flow some of the coolant through. It may not be ideal, but it wont hurt to do.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
lakeffect2
Aug 23, 2015 08:44 AM
86White_T/A305
Aug 17, 2015 12:16 AM
