using transmission fluid as power steering fluid
Old Nov 13, 2012 | 10:42 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i pulled a PS pump off a 79 chevy truck to use on my car, while i was isntalling it my dad told me i could use transmission fluid in it instead of me having to go buy power steering fluid, iv seen and heard of others doing this, would this hurt anything? the pump had tranny fluid in it when i took it off the truck.
Old Nov 13, 2012 | 11:19 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: using transmission fluid as power steering fluid
No Way
Old Nov 13, 2012 | 11:27 PM
z28_87Camaro's Avatar
Car: 1987 Z28 / 1988 IROC-Z
Engine: 305 LG4 / 305 LB9
Transmission: T5 5spd
Axle/Gears: 3.42 / 3.08
perfectly acceptable to use tranny fluid in our power steering pumps. I have for years. Not much difference between the two. Costs cheaper too.
Old Nov 14, 2012 | 06:32 AM
Yes it does "work". Not quite as well sometimes but it's "OK". Used to be what everybody did; might still be what some people do.
OTOH, there's only like $2 worth of fluid in the thing, even if you buy the "expensive" stuff... might as well use the right stuff to begin with.
I'd strongly recommend popping the pump out of the reservoir and changing out the BIG O-ring around it, so that your next post isn't about something like "I just got an old used PS pump and it leaks".
Old Nov 14, 2012 | 06:37 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i see no problems using tranny fluid.
ive been using it in my power steering pumps 25 years with no problems.
Old Nov 14, 2012 | 06:38 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
It'll work. I use it in my 04 grand am because it has a leak causing me to refill every week. I'm a tech at a Ford dealership so tranny fluid is free. Ford actually only uses Mercon V in their power steering. They don't have an actuall power steering fluid.
Old Nov 14, 2012 | 04:04 PM
Engine: L31 350
I accidentally over filled my pump, how do I take some of the fluid out?
Old Nov 14, 2012 | 04:22 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
in a pinch, you can stick a straw or small hose in there, then put your thumb over the other end and pull it out. just like you can do with a straw and some soda. just gonna take a few times.
Old Nov 14, 2012 | 05:55 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
go grab your moms turkey baster , it will destroy the bulb but will do the trick and there only a buck or so to replace.
Old Nov 14, 2012 | 09:26 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Where have I heard that before ?!?!
AFT is said to deal with the heat better than PS Fluid. It's widely recomended by many by truck, SUV, 4x4 owners.
If you don't have one already, think about adding a factory PS cooler to your system. They add capacity and really help cooling the PS fluid temps. The use of an in-line filter is also quick, cheap, worth-while modification. ( Don't believe me; try and and see for yourself ! )
Old Nov 14, 2012 | 10:15 PM
Engine: Lb9
Transmission: M20
hey mom the turkey tastes like dextron this year
Old Nov 14, 2012 | 10:46 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Every noisy/whining PS system I hear coming down the road is on a Ford. Just saying.....
Old Nov 15, 2012 | 06:44 AM
built91Z28's Avatar
Lol, they do have one style of pump on the older cars and trucks that won't shut up. We won't even usually sell customers a new one if their only complaint is noise just because we already know there is a good chance the new one will be just as noisy. Sometimes a bottle of friction modifier (posi addiditive) will quiet them down.
Old Nov 15, 2012 | 05:53 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Did you remember to bleed the system before taking the "extra" fluid out of the pump? If not, jack up the front wheels and turn the steering lock to lock several times WITHOUT the engine running and check again.
BTW, you can also use brake fluid in the PS. But don't even think about using PS fluid in the brakes if you want the car to stop when you hit the pedal...
Old Nov 15, 2012 | 06:17 PM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
I just use the stuff called for. Like someone else mentioned it's not that much. If it leaks probably should just fix it.
Haven't had to add any for long time, but from memory I seem to recall the PS fluid being noticeably higher viscosity than ATF.
Old Nov 15, 2012 | 06:30 PM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
Free? Really? Is that part of your official wage and benefit package?
Old Nov 15, 2012 | 10:43 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
I'm also a mechanic at a ford dealership. I can get any ford fluid or shop supplies for free. Basically its what you have left over from working on customers cars. Could be a little or could be alot.
Old Nov 16, 2012 | 04:05 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
Only drawback I have seen to using the transmission fluid is I have seen it foam up in the pump and caused it to whine and become jerky. The solution was to put an antifoaming agent in it.
Old Nov 16, 2012 | 05:52 AM
built91Z28's Avatar
Basically. Trans fluid and 5w-20 oil are both in 200 gallon containers. We just take it when we need it. Oil changes only cost me the price of a filter also.
Old Mar 2, 2013 | 04:07 AM
fast400's Avatar
Car: 89 TTA
Engine: 3.8
Transmission: 200r4
Not to tit pick, but why would you use 5-20 in a warm climate like orlando???
Old Mar 2, 2013 | 09:42 AM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Lucas makes a PS fluid and also guaranteed to stop leaks.
I about to try it, steer box is leakin.
Old Mar 2, 2013 | 11:39 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I understand that the key difference between PS fluid and ATF is anti-foaming agent. ATF is more apt to foam up. I have used the Lucas PS Fluid additive. It does quiet down a noisy pump and slows down leaks but don't add too much of it or you'll have very hard steering on a cold start up. The best thing you can do for your power steering or any fluid system on your vehicle is change out the fluid regularly. ATF, gear lube, PS fluid, brake fluid. It all gets contaminated over time and needs to be replaced on regular intervals. 2yrs, or 30K mi is about standard on most fluids. More often if you run it hard.
Old Mar 2, 2013 | 12:41 PM
Chad85T/A's Avatar
Car: 85 T/A
Most of the newer fords call for 5W20.
Old Mar 2, 2013 | 12:48 PM
Damon's Avatar
If you're road racing and working the PS hard, use the right stuff. If it's a typical street car, ATF works fine. It's the same base oil, just a slightly different additive package and different color. I don't think I've put actual PS fluid in any of my street drivers in 20 years.
Old Mar 3, 2013 | 01:15 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
There are some viscosity differences between the two. Not enough to bother a GM pump, but if you've ever heard a ford PS pump that called for ATF have regular PS fluid put in it by mistake, youll get what I mean.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
spaigo
Aug 21, 2015 07:46 PM
