high idle in cold weather
Old Nov 16, 2012 | 10:50 AM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
hi i will give you a little info about the car first. 90 rs camaro, swapped in a supped up 350 and had the chip re tuned to the new motor. as well as a high preformance tbi. the past 4 months it has been idling high around 1800 rpms when it has warmed up and i am stitting at a stop light. and it mostly does this when it is cold out. like below 40 degrees F. whats going on? tried adjusting the idle screw in the tbi and i still cant get the rpms down. thanks
Old Nov 18, 2012 | 06:39 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: high idle in cold weather
What?!?!?!?
Old Nov 20, 2012 | 04:31 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Does a TBI have a high idel adjustment? I assume it would be on the passenger side of the TBI.
Old Nov 20, 2012 | 05:34 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Have you verified no vacuum leaks?
Old Nov 25, 2012 | 09:25 PM
Piston454's Avatar
Car: 1990 RS Camaro
it does have an idle adjustment on the passengerside. and i have tried adjusting it. i havent checked for vacuum leaks, because it only does it in cold weather. and i havent had a proublem with it when i first bought it 3 years ago and it just randomly started it these past few months.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
86IROC112
Aug 21, 2015 07:20 PM
