Knocking sound after driving 2hrs HELP!
Old Nov 17, 2012 | 10:59 PM
saldav420's Avatar
Car: 86 bronco, 88 iroc
Engine: 351 windsor, 350 tpi
Transmission: 700r
88 iroc 350 tpi. I just got the heads rebuilt less than a month ago. I took a 2hr trip and when I parked it to unload stuff and turned it on again I heard knocking sound comming from what I'm guessing the lifters. Idk know if it's my oil thinning out or what. Also my service engine light came on with code 36 but that happen first when I arrived to my destination. The knocking happened when I got back home. Could anyone help me trouble shoot this problem, I really appreciate any help possible, again thank you in advance.
Old Nov 18, 2012 | 11:25 AM
88FormulaF_Bomb's Avatar
Car: 1988 firebird formula 350
Axle/Gears: 2.77
i did about 5min of reading after i googled it and found that a bad crankshaft position sensor can cause code 36 and engine vibration/noise.
Posted from Thirdgen.org App for Android
Old Nov 18, 2012 | 11:35 AM
Axle/Gears: 2.77
also a maf sensor error can cause code 36 but i dont see how that would cause an engine "knock"
Old Nov 18, 2012 | 11:49 AM
saldav420's Avatar
Transmission: 700r
Re: Knocking sound after driving 2hrs HELP!
Where would I find the crankshaft sensor?
Old Nov 18, 2012 | 12:17 PM
Axle/Gears: 2.77
idk i would just google it. or wait for a more experienced member to respond.
Old Nov 18, 2012 | 12:30 PM
saldav420's Avatar
Transmission: 700r
Ok ya I'm going to google it for now, and wait and see if someone else replies. Thanks for your time googling lol. Ps how good does the thirdgen.org app work is it easier than using the browser on a phone?
Old Nov 18, 2012 | 12:33 PM
Axle/Gears: 2.77
its very easy to use and makes work fly by. i also googled the sensor location but didnt find a strait answer yet. good luck
Old Nov 18, 2012 | 01:00 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Let's keep this simple. Googling things tends to get people in trouble.
There is no crank sensor on a thirdgen. Period.
Code 36 is a MAF burn-off circuit error... Possibly a bad relay.
Take your valve covers off and check the adjustment of the rockers.
Old Nov 18, 2012 | 01:09 PM
Axle/Gears: 2.77
wow death to google. how does a maf error cause the "knock" he described?
Old Nov 18, 2012 | 01:20 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Depends on what's knocking. Like I said, he should check the rocker arms first.
If there is a code 36, then chances are the MAF wire is dirty. If the wire is dirty, it's not telling the ECM how much air is entering the engine. If there is more air than it's telling the ECM, the ECM runs the engine LEAN. And we know what happens when the engine runs lean for a long enough time (BOOM).
Old Nov 18, 2012 | 01:43 PM
Axle/Gears: 2.77
ooo so the knocking might be a result of running lean for too long?
Old Nov 18, 2012 | 02:28 PM
Engine: 2.7L V6
Axle/Gears: 4.41
After being at a certain speed for a certain amount of time, the ECM enters "Highway" mode. This mode leans out the fuel mixture, saving fuel on longer trips. This could be a part of the problem, and the other part could be that the oil thins out and doesn't allow the lifters to pump up properly, creating slack in the valvetrain.
Old Nov 19, 2012 | 12:11 AM
saldav420's Avatar
Transmission: 700r
The MAF was replaced 3 months ago. Where would I find the relay for it? I only hear it when the car gets warm.
Andrew6.688
Dec 13, 2015 10:59 AM
gta90
Sep 15, 2015 04:00 PM
db057
Aug 22, 2015 08:17 PM
gwade12
Aug 8, 2015 08:17 AM
