RPM GAUGE IS OFF
Old Nov 18, 2012 | 05:02 PM
THTHREAT's Avatar
Car: 1991 firebird
Engine: 305 tbi
Transmission: STANDARD( REBUILT)
Axle/Gears: N/A
RPM GAUGE IS OFF
i NEED HELP MY RPM gauge is about 1300 off, i have no idea how to get it but when im idling its not rev-up high... sound normal but its holding at 2000, i am seeing 6000 when i shift gears when it should be what 3000?
somone help please
THTHREAT
Old Nov 18, 2012 | 06:38 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: RPM GAUGE IS OFF
Soudns like the gauge is wrong/bad, especially if the car runs well. How about when you're driving, doe the RPM gauge ever go over 2000?
Old Nov 18, 2012 | 07:21 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
When did this start? Was it reading correctly prior to replacing something? Did you replace anything before it started reading incorrectly? Gauge? Transmission? Rear end? Wheels/Tires? Do you know if it is actually reading incorrect?
Old Nov 18, 2012 | 08:51 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
If it's an electronic, rather than mechanical, tacho you'll probably find one of the capacitors had dies from old age.
Do a search, there are threads that explain how to repair it. Parts cost 50c.
Old Nov 19, 2012 | 05:49 PM
THTHREAT's Avatar
Car: 1991 firebird
Engine: 305 tbi
Axle/Gears: N/A
I dnt know i just got the car, and it doenst rev high, but the tach reads 3000 when i start it, then it shifts in the 6000, when i turn off the car it stays at 2000, i have to turn the key back on to drop to 0, then once in the off position it comes back up to 2000.
Old Nov 19, 2012 | 05:51 PM
THTHREAT's Avatar
Car: 1991 firebird
Engine: 305 tbi
Axle/Gears: N/A
where are these capacitors? i am new to this, ive had a few when i was younger, and always like the car.... just bought it off some kid, sunk 2400 into the transmission the 2nd day,.. but it was doing it before that. i thought it would be better since the trany rebuild but its not.
Old Nov 19, 2012 | 06:06 PM
peterc005's Avatar
Transmission: T700
You'd need to remove the gauge cluster and replace a capacitor that is soldered into a printed circuit board on the rear.
Your transmission does not affect the tacho.
Old Nov 20, 2012 | 04:48 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Or find a donor car in a junk yard and relieve it of it's cluster and tach and see if that fixes it.
Old Nov 20, 2012 | 10:09 AM
peterc005's Avatar
Transmission: T700
Some types of capacitors just fail with age, so replacing an old cluster with another old cluster may not achieve much.
Old Nov 20, 2012 | 11:18 AM
Ozz1967's Avatar
Car: 1984 Trans Am
That is true, however, it may still work, and then he'll be better than he was.
Now, your saying the car doesn't REV high? When in idle, and you put your foot down, the car should roar...as the RPMS jump. Does the car do this or does it flat line/not rev high? Remember, 5K RPM is HIGH for these cars...
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
