Full lock issue
Old Nov 21, 2012 | 10:41 AM
Irishknight2000's Avatar
Full lock issue
Hi Lads(and ladies)
Have a v6 Firebird with an issue Id like to get sorted if possible if anyone has any thoughts or maybe went through similiar
Basically at full lock/full turn of the steering wheel, the car struggles to drive, it feels like it is rubbing at the arches and goes really really slow if at all.......only a full lock, normal driving is fine no probs but the likes of tight turning or parking spot the above happens.
Tyres have been replaced to factory size, new balljoints, tierods, brake pipes, drop links.
It feels as though wheels are dragging it that makes sense, looked under can see nothing bent or warped, mechanic confused, also another 3rd gen owner confused.
If anyone has any idea of what could be or what might help Id be gratefull.
Old Nov 21, 2012 | 04:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Full lock issue
This has to do with the suspension geometry and it normal/common on these cars. Check the suspension/chassis board here for lots of posts on this. IIRC, it has to do with the Akerman angles. Which is how one wheel turns to a different angle then the other as the steering is moved off the straight line position.
RBob.
Old Nov 22, 2012 | 03:17 AM
Re: Full lock issue
Thanks for that Rob, first I heard of it but done a bit of reading as you said and yeah thats it. Glad nothing wrong with steering mechanism so just have to live with with......small sacrifice ha. Thanks again
Old Nov 22, 2012 | 07:43 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: Full lock issue
i thought that a crack in the fram by the steering box could be the cause of this also ?
Old Nov 23, 2012 | 04:13 AM
Re: Full lock issue
Thanks Freaky, Since was pointed in right direction have done a bit of reading up, cant say Ive noticed but as its common I will give it a good check again.
Think will change out the control arm bushings and get one of those Wonderbars too see it helps.
Thanks Lads
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
Dialed_In
Aug 20, 2015 01:45 PM
