what's the difference?
Re: what's the difference?
Oil pressure gauge range is 0-60 in V8s (in some years at least, not sure about 92); 0-80 in 6-cyls
Tach reads 1 rev for every 3 pulses (since half the cylinders fire in each revolution) from the distributor of a 6-cyl; 1 rev for every 4 pulses from the dist of a V8
Of course not. The tach will read 33.333% (8 ÷ 6) higher than actual engine RPM. Since these tachs always fail by reading high anyway, not a good idea.
The oil pressure gage though, if you put a 6-cyl sending unit in the V8 motor, that gauge will read right.
is it okay to put the v6 motor for the speedometer in the V 8 with the keyboard plug into it and if so where could I get that motor besides the junk yard? sorry for all this questions I once.if is easier can u call me at 954-605-5854 thanks!
Numbah-1
Sep 12, 2015 08:57 PM
