sputtering and tranny ???
Old Nov 26, 2012 | 11:24 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
question #1. only happens when i havent drove it like overnight or so when i start the car and put it in drive it will take literally up to a full min at time before it engages into drive and after it warms and it will engage right away. fluid is clean and full.
question #2. also when first starting the car sputters alot. almost sounds like its missing, i smell fuel. and alot of black smoke out of the exhaust. but when the motor warms up it respones fine most of the time, sometime it still hesitates or misses, i have a new air inlet temp sensor, the car does seem like its burning through fuel alot faster, might be running rich as well. how would i check and adjust that??
car is a 91 camaro rs v6 auto
Old Nov 27, 2012 | 06:22 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: sputtering and tranny ???
Question #1 This can only be 2 things, 1 you are super low on tranny fluid, or 2 the seals in the transmission are hard as a rock and are not sealing allowing blow-by until they get warm and soften up.
Question#2 What codes if any is it throwing? If it was me I would start at the coolant temp sender. Do a search and figure out what ohm reading you should have with the ambient temperature out side on a morning after it has been sitting all night. I bet it is bad and telling the pcm its way colder than it is.
Old Nov 28, 2012 | 11:15 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
thanks for the advice. well it must be the seals in the tranny. the fluid is all good. and ill be sure to check that sensor soon as i can
db057
Apr 28, 2019 07:45 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
