engine during in gear
Car: 1991 camaro rs
Engine: 350 bored .030 over, 438rwhp 429tq
Transmission: 700r4 stage 3 race 700hp
Axle/Gears: stock axles and 3.23 gears
when I pull my car in gear it bogs down and will die after bout 5 seconds if I can't roll or give it gas. is this vacuum related or ignition or timing or what. I can't even drive it.cuz its such a pain. built 355 solid cam 501 lift 297 301 duration stock stall stage 3 race 700r4
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: engine during in gear
What are the @50 duration numbers on the cam?
Most likely you will have to raise the idle speed to allow for the cam ( and possibly change the stall as mentioned )
If you are making the Hp you claim from a 355 then no way is it gonna idle like stock
What induction do you have?
Usually that's a matter of tuning; idle speed & mixture, having enough ignition timing, etc.
What cam is it? (part # or grind # ONLY please)
What kind of carb? How's it set up? What's the timing curve?
THe stock converter probably isn't helping, but it should idle, regardless. Usually that just makes a car have no "leave".
Car: 1991 camaro rs
