88 iroc tpi 305 was running fine now has no spark at all!!! NEED HELP ASAP TGO!!!
Old Dec 2, 2012 | 10:47 PM
mygta87's Avatar
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
ok so swapped the 305 tpi into a 88 iroc has new lifters, cam, pushrods, timing chain,head gaskets, intake manifold gaskets,oil pump new cap rotor ignition module coil wires and spark plugs. so the car wouldnt start yesterday but the thing was distributor had to be turn 180 degrees away from #1 piston.
set the distributor yesterday and started right up did valve adjustment afterwards was running fine...
started up this morning fine ran fine shut it off, checked the car for everything being tight and removed it off jackstands. when to eat came back to start it and go for a test drive now it just cranks i turn the distributor and no reaction to it.
THINGS IVE DONE AND CHECKED-
check the #1plug wire for spark and nothing checked the coil for spark nothing, removed cap and turn it rotor spins, plugs seem to be dry no gas on them,
what i think is a ground since it was on jackstands and started up fine removed them and nothing maybe or distributor gave out or ecm i checked the fuses nothing im going crazy please help TGO thanks text since im not always on to 5107061708 or just post on here
Old Dec 3, 2012 | 05:33 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 88 iroc tpi 305 was running fine now has no spark at all!!! NEED HELP ASAP TGO!!!
Given you appear to have no fuel and the injectors are controlled by the ECM
after it gets a signal from the ICM in the dist which also controls the spark , seeing you are missing both
the ICM would be the 1st thing I would check
Read
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Old Dec 4, 2012 | 07:46 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Fuel pump being primed with the iginition to "on"?
Check all your fuses.
Test your ignition module. Mine went out and I got no spark from the dizzy. It was sudden too. I went to Mcdonalds for dinner, parked, went inside, came out and nothing...dead.
Old Dec 4, 2012 | 12:14 PM
mygta87's Avatar
It was the distributor, now car hesitates has no power how to set perfect timing need a timing gun?
Old Dec 4, 2012 | 12:21 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Could have been the ignition module in the dizzy.
And yes, you'll need a timing gun to set the timing properly.
Old Dec 6, 2012 | 10:31 AM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
+1 vote for ICM without even lookin at the car
Old Dec 7, 2012 | 08:02 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Back In the days before the LSx engine was in the maro i always carried an extra ICM with me lol. Now with the LS i keep a fuel pump with me lol.
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Sherpajames
Aug 7, 2015 06:56 PM
